reverse polarity on capacitor
Started by newbie builder, June 05, 2006, 11:37:01 PM
newbie builder
i just fired up a circuit and it didn't work. then i realized I had reversed negative and positive on the 10 uf cap. then i fixed it...circuit still doesn't work. could i have damaged something? (there is an IC in the build, that's the only socketed thing/only thing i could think might be damaged)
also this is the project i was doing: http://generalguitargadgets.com/pdf/ggg_ic_buffer.pdf
my first perfboard project...
Quotecould i have damaged something?
Yes, you sure could. That 10uF cap could now be shorted. At a minimum, pull it out and check it both directions with the resistance setting of your ohmmeter. Better, just replace it.
