protection diodes
Started by scaesic, June 09, 2006, 01:05:14 PM
scaesic
are 1n4002 rectifier type diodes good to use after the output buffer as protection?
scaesic
GibsonGM
protection against what, on the output buffer of what?  I usually use them in the power supply line in case someone hooks up a battery backwards (reverse biased)
JHS
Protection after the o-buffer? For What?
To me this make no sense, a protection before the i-buffer is OK (if you run a SHO or other Gain Booster in front of it) but I think even this is not  really necessary.
JHS
scaesic
basically its at the output on a distortion box. Both clean and distorted channels are biased to vs so when you switch it's a bit dodgy, so after the switch wiper there's a cap to Vs followed by an unity opamp followed by a a pair of diodes going to + and - rails. I assumed it's to prevent any oscillations whilst switching.
Here's the schem!
http://www.diystompboxes.com/pedals/dist2.GIF
Sure, 1N4002's will work as well as most diodes there.
scaesic
GibsonGM
I'd use 'em...I think the 1N4XX series only differ by their max voltage ratings...Vf should be the same.  ;)
http://www.diystompboxes.com/smfforum/index.php?topic=45986.0
