GA5T preamp layout
Started by RLBJR65, June 14, 2006, 11:35:11 PM
RLBJR65
Yeah, I know these amp fet emulations have pretty much run their coarse... but it sounds so good as a pre amp for a 386 amp that I thought I would post it anyway. Based on a Gibson Skylark Tremolo amp model GA5T. Still working on the Tremolo portion of the circuit.
Vero layout is untested! I will post the perf layout I used soon.
http://aronnelson.com/gallery/Richard-Boop-RLBJR65/GA5T_Preamp?full=1
The Layout was done with bancika's DIY layout creator. What a wonderfull program! If you have not tried it out yet take a look. Here is the thread, it's getting quite long.
http://www.diystompboxes.com/smfforum/index.php?topic=44838.0;topicseen
Download the program from bancika's web page. http://www.storm-software.co.yu/diy/index.php?project=layouts
Richard
Richard Boop
MartyMart
Looks great Richard, couldn't it use a "master volume" at the output ?
A standard 100k log should work as an overall vol control.
cheers and thanks for the time/effort
Marty
MartyMart
Just quickly built this, sounds very "tasty" and I like the fact that it's a lower "gainer"
It has a lovely "sparkle" to it and certainly has it's own "voice"
Works fine, though the tone pot seems to be backwards  :icon_redface:
I used 2k7's off both gates and a 4u7 cap off Q1/22uf off Q2, so I have a bit more
gain at the top end ,,,,,,,,, ( running out of parts badly !! )
Added a 1M pull down resistor at input and a 1N4001 protection diode/100uf/100nf PS filter cap.
Also added the 100k master volume pot at the back, works perfectly.
Cheers,
Marty.
RLBJR65
Thanks Marty. Your discription is right on. I sometimes have a hard time telling others what I hear.
Can't remeber if the tone worked backwards on mine. I'll have to take a look when I get home.
BTW Here is the original schematic I was working off of. http://www.schematicheaven.com/gibsonamps/skylarkga5t.pdf
I liked the "sparkle" and lower gain. It cleans up my 386 amp at lower volume. I have not tried it with a Ruby but suspect it would have the same effect. Some guys may want a little more gain though. I'll add your mods to the layout.
Great Idea adding a master volume pot! Why didn't I think of that?
I've got alot going on right now, not much time to build but I hope to get the tremolo working to some day.
Richard
Richard Boop
MartyMart
Sounds great into both valve/SS amps, also nice direct through a speaker sim :D
Look forward to the trem section ......  :icon_wink:
MM.
RLBJR65
Never got a chance this weekend to take a look at it. Helped my neighbor pour and finish 18 yards of concrete, eeeyuck. Then helped my nephew put together a play yard club house thing for the kids. The play yard was supposed to take 10 hours, yeah right ??? Maybe with a 4 man crew >:( Also installed 2 air conditioners, mowed the yard, took the dog to the vet and put together my Fathersday gift. It was a hammock BTW and I actually got to try it out. Just long enough to drink a beer though! Sometimes weekends like that make me look forward to all the traveling I have to do during the week.
Anyway... maybe the tone pot should have lugs 3 & 2 connected to C3 and lug 1 to ground instead? The schematic just shows a variable resistor to ground. Or maybe it should be a reverse rotation pot.
Did you add any roll off caps or anything? I thought it sounded really good as is so I didn't bother trying.
I had the lfo working by itself just subbing a fet for the tube but it did not work (no trem) in the circuit. I'm thinking that another transistor needs added something like ROG's EA trem. Or maybe I just screwed something up the first time. Anyway it needs a depth pot so I'll have to add some stuff and play around with it. Maybe I'll get a few minutes with the bread board this weekend.
As always your input is appreciated. If you have any more ideas or suggestions please let me know.
Richard
Richard Boop
MartyMart
Sounds like a busy weekend !!
I spent mine travelling and working ( concert in Dortmund )
I didn't add the double freq roll off section, seemed to sound fine without it, perhaps that's
what gave it the "sparkle" !
Dont sweat over the trem section, there's plenty of simple and good trems around ( Kay/EA etc .. )
MM.
