Homebuilt Dunlop Wah- No Wah?
Started by vfr800fiman, June 27, 2006, 01:02:55 PM
jonathan perez
vfr800fiman
What is the difference between mechanical engineers and civil
Engineers? Mechanical engineers build weapons and civil engineers
Build targets.
Paul Marossy
That schematic has always perplexed me. The original wah used 0.22uF caps, not 0.001uF caps...  :icon_confused:
alderbody
Quote from: Paul Marossy on June 28, 2006, 11:11:44 AM
I don't think there is much of a difference between the 4uF cap and the 4.7uF cap, but some people hear a difference. To me, it's not enough to be overly concerned about.
Here's what i found about 4uF caps:
http://www.diystompboxes.com/smfforum/index.php?topic=46526.0
The difference is mostly in the way the effect operates and not in the way it sounds.
alderbody
QuoteI guess I just don't understand why the volume is reduced so much after it passes through the
.001uF cap.
maybe it's a bad cap... Did you try another one of the same value?
QuoteCan I still use the 2N3904's and change the rest of the components to the VOX circuit? or do I have to also switch to MPS-A18's?
I would assume the bias is different for these xsistors, so maybe I have to change the resistor values as well?
You can try anything that sounds good to you, as long as the specs match...  (mind the pinouts!!!)
For insatnce, i use a NPN Ge transistor for Q1 in my wah and a BC108 for Q2, and i didn't have to change anything else.
I put sockets so i could try some until i found the ones that sounded best for my setup.
Maybe you could replace Q1's emitter resistor with a trimpot so to adjust the gain of Q1. (lower values raise the gain)
btw, MPSA18's sounded really flat to me...
If i remember well, Q1 should be around 200Hfe for best results. (read R.G.'s article)
As for the inductor's resistance the 30 Ohms is the key...
I have a Fulltone inductor which is around 30 and it's awesome, while my Banzai is below 30 and it's not as chuncky as the Fultone.
btw, i use them both in my Wah, interchangable through a DPDT switch.
moody07747
If it were me, I would dump that 0.001uF cap and use a 0.22uF - it'll sound fuller that way. I don't think there is much of a difference between the 4uF cap and the 4.7uF cap, but some people hear a difference. To me, it's not enough to be overly concerned about.
I just picked up a original crybaby...
only thing i dont really like is the tiny movment in the sweep....i have to do something about that
anyways im going to swap that .001uF to a .22 for my first mod.
Dave
http://sonicorbstudios.squarespace.com/
Sonic Orb Studios
The Media Specialist
vfr800fiman
I guess I'm going to swap over the .22uF cap. as it seems like everyone agrees on this value.
I always socket my xsistors using SIP sockets trimmed to 3 positions, works great.
Thanks for all the suggestions. I'm going to look at a few of these things this weekend.
This board has always been great in helping me troubleshoot!
Thanks again everybody.
Glenn
Build targets.
