grounded circuit input true-bypass
Started by powerplayj, June 29, 2006, 09:00:55 PM
powerplayj
Do the switch grounds go to the board or to the in/out jack grounds?
http://www.diyguitarist.com/PDF_Files/GCI-TrueBypass.pdf
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
powerplayj
One other thing, is "effect in" the board input or the lead from the input jack.
next build(s): ???
bioroids
I think effect in and effect out are the board in and out.
The switch ground should go to the board ground. The jacks ground have to go to the board ground too, though that part of the circuit is not shown.
Luck!
Miguel
Eramos tan pobres!
Paul Marossy
QuoteI think effect in and effect out are the board in and out.
Correct.
QuoteThe switch ground should go to the board ground. The jacks ground have to go to the board ground too, though that part of the circuit is not shown.
Correct.
powerplayj
Just realized the issue.  Since the lugs are 3 X 3, orientation is EVERYTHING!  I wired it up with the lugs oriented vertical as in the drawing which was incorrect on my part.
next build(s): ???
