transistor 5117 data sheet
Started by Doc001, July 02, 2006, 04:43:33 PM
Doc001
anyone have a data sheet for a 5117 transistor? or know where to find one?
toneman
google for 2N5117.
dualPNP.  obsolete.
Doc001
thanks toneman. i still ain't having any luck. :-[
Aharon
I have some notes I made on the 5117/5115 transistor from my wha build......pinout device flat side facing you :ECB.Sorry that all I got......
Oh,also .....subs=NTE123AP
Aharon
Doc001
#4
thanks for the replies, i appreciate the help  :)
toneman
another 2 sec google...."2n5117  intersil"   or "2N5117 datasheet"
result---
http://www.obsolete-transistors.com/pdf/2n5117-datasheet/2n5117-datasheet.html
save_as :  datasheet.etc etc..  a pdf file....  8)
all the data; all the time.
simple as google.....  ???
afn
T
lacto
Is that what you wanted? Because the 5117 silicon NPN transistors used in 70's Crybaby wah pedals are not 2N5117's. The number 5117 is a part number from Thomas Organ company. They are standard T092, e-c-b left to right on the flat side. Although they are obsolete, you can find them for $8 to $15 a piece at a couple of places. According to Ed G. on this forum the modern day equivalent is 2N2925.
Doc001
Quote from: lacto on July 03, 2006, 01:42:53 AM
the 5117's i have are out of a crybaby a friend gave to me. the  ones that toneman found was all i was able to find any data sheets on but, not what i wanted. i was successful in soldering the 5117's onto my board, per Aharon's instructions last night, and the pedal sounds great.
again , thanks for the assist guys/gals. i appreciate all the posts.
