Payback : Layout
Started by Michael Allen, July 11, 2006, 11:15:31 PM
Michael Allen
Here is my layout. It won't fit vertical in a Hammond, but you can fit er in a 1590B. It's 70mm by 33mm.
http://www.freewebs.com/loudnoise/payback.PDF
Michael Allen
for some reason there is some clipping in the layout picture.... i'll try and fix that...
j.frad
Great! one question though, is the part layout viewed from the component side of the pcb? if so, maybe the "payback" writing should be written reversed so that you can actually read it when looking at the copper side like on the tonepad files for example. This would help etching the right orientation of the pcb.
I don't know if I'm clear enough...
Did you verify this layout? It's a great looking piece of work!
Michael Allen
The layout has been runthrough, so it should be good to go. Yeah, the payback is reversed, but my PCB stock is transparent enough that I can see writing through it....
The Tone God
That one works much better then first one. GREAT Stuff Michael! Thanks for all the effort. Better then the crap I would have put out.  :icon_redface: :icon_rolleyes:
Andrew
Michael Allen
Thanks guys! I just put together an update for the vanishing point 2 board I made, maybe I can finally get rid of the clock noise I had in mine... too much to do!
sshrugg
THREAD RESSURECTION!  :o
I grabbed me some ISD2560s and plan on building this.  I see that this layout is different than the one in the other Payback thread.  It has the corrections that The Tone God has mentioned.  Before I start soldering though, I just wanted to ask if anybody can verify it.
-Danny
Built: Fuzz Face, Big Muff Pi (Stock), Distortion + (Germanium and Silicon versions)
