Easy Face blend input cap
Started by Jazzman, July 14, 2006, 04:44:46 PM
Jazzman
Hi
A while ago i built an Easy Face with blend input cap(as seen on the General Guitar Gadgets page).
Instead of the hybrid version i used two AC188's.
It sounds really good, but not much happends when i turn the blend knob. It sound as if i had only the
"big" capacitor in there.
I would really like to be able to make it less fat sounding. Does anybody have an idea what could be wrong?
By the way: what would a sillicon transistor in Q1 do to the sound?
-Jazzman
  miswire
  wrong value pot
  or something else best found with a DMM...
  blind guesses based on less than vivid memories of the schematic
Jazzman
Hi
Thanks Peter. I have checked the wiring, and it should be ok.
Could it be the cap values? They're 0.01 and 2.2 uf. One is
electrolyt and the other metal film.
-Jazzman
  .o1uf...Smallish, about the min value I like as FF C1
  2u2, large value should let lots of mud in...
  Has the DMM revealed any 'secrets'?
  Id' go through withe DMM set for 'beep/continuity' and test the Resistances of the pot [from wiper to one Outside Lug, then wiper to other OL] settings.
  I've had problems with *actual connections that 'look made.
tungngruv
I used a .0047 and 3.3uf combination on mine. Get's really fuzzy at the 3.3uf side and almost "overdrive like" at the .0047. Maybe you have a bad pot?
Jazzman
Hi again
Thanks for the input, everyone-really appreciate it!!
I tried replacing the 0.01 cap with 0.0047 and now it works!!
It sounds great, but it seems to lose some gain. No big deal, however, as
i'm going for a more overdrive-like tone in that end of the pot.
-Jazzman
