What effect is used early in LA Woman ?
Started by brett, July 17, 2006, 10:53:45 PM
brett
Hi.
There's a very cool fuzz used early in the song.  Slightly "crackly" and gated.  Sounds like a milder version of the FZ-1 used in "Satisfaction".  Any ideas?
Thanks.
Brett Robinson
Herr Masel
I think Robby Krieger used the fuzzrite, which is not mellow at all compared to the tonebender on satysfaction! The mellowness could come from the fact that he played with his fingers (no pick), and maybe rolled off volume/tone on the guitar. I really like the way he uses fuzz.
RedHouse
FYI, the Satisfaction fuzz was not a Tonebender, it was a Maestro FZ-1
jrc4558
It seems to me that first off you would need an SG with P-90's
brett
Hi
The Fuzzrite looks very interesting.  Will build one ASAP.
It also looks ripe for experimentation, as it was obviously designed for old, low hFE transistors.  Hence those whopping 470k resistors on the collectors.  I might knock them down to 220k or put a pot in there and see how low they need to go for a pair of modern 2N3904s.
thanks
Brett Robinson
Herr Masel
#5
Quote from: brett on July 19, 2006, 01:59:53 AM
Do you mind to explain please what you mean by this? What do the resistors do to the collector of a low hFE transistor?
EDIT: http://www.diystompboxes.com/smfforum/index.php?topic=47264.msg348591#msg348591 ok I saw the other thread!
brett
Hi.
The collector resistor is important in this circuit for at least two reasons.
1.  Asuming that we're working at less than the transistor's maximum gain, the gain is approximately equal to the collector resistance divided by the emitter resistance.  Ah! But you can clearly see that there's no emitter resistor.  True, but the emitter has a small internal resistance (depends on the base to emitter current - usually a few ohms).  So making the 470k collector resistor smaller would reduce the gain.  Halve it, and the gain goes down by half.
2.  Because of the biasing arrangement in this circuit, the collector resistor also affects the base (Ib) and collector (Ic) currents.  That is because the transistor is turned "on" by a small amount of current flowing through those 2 x 470k resistors.  If we assume the base is at 1V and the battery + is 9V, the base current will be about 8uA (8V/940k).  From this we can also calculate Ic, because the transistor amplifies Ib by hFE (say 500 for some modern transistors).  8uA x 500 gives 4mA, which is a fairly large collector current.  If we reduce the collector resistor from 470k to 10k, the base current goes up to 16uA, and the collector current up to 8mA.  Because the original circuit had 2 x 470k resistors and low hFE transistors (150?), the original circuit probably had Ic about 1.2mA.  Having Ic of 4 to 8 mA may affect gain and tone, and will affect battery life, so I'm now thinking that I'll use  low gain transistors, like BD139s, and keep the 2 x 470k resistors on each transistor.
So, I've changed my mind and feel that keeping the collector resistor large (470k) and keeping transistor hFE low (150) is probably best.  (It will also keep the tone authentic).
That may not be too clear.  If not, ask again.
cheers
Brett Robinson
fixr1984
Hi
I would deffinatly recomend this to anyone.
Check out Dragonflys layout HERE
Or mine is found  HERE
My layout has been verified. R1 and R2 are the resistors Brett was talking about, the layout calls for 10k, I used 100k.
Paul Marossy
Hmm.. that's an interesting circuit. What's up with those odd pot values? 350K & 33K?
markphaser
Looks like to me the Fuzz rite is a "Differential" fuzz amp
When it gets off balanced (not equal to zero) it creates fuzz or break up on the output
The 350K is the balanced (fuzz) pot
The 33K is just a output volume pot
What kind of "biasing" does the fuzz rite use for each stage? because its not BASE BIAS or COLLECTOR FEEDBACK BIAS
puretube
RDV
Wasn't there a built-in fuzz in those Acoustic(?) amps Kreiger was using at that point? I had heard that was what was used on "Break on Through".
RDV
brett
Hi
QuoteLooks like to me the Fuzz rite is a "Differential" fuzz amp
Yeah, it seems to output a mix of an amplified inverse signal (collector of Q1), and its amplied inverse, amplified inverse (collector of Q2).
Because the signal out of Q2 is in-phase with the input (because it has been inverted twice), it probably encourages the oscillations and feedback reported for this circuit.  An inverter at the output may be useful.
Concerning that weird 350k pot, I'm going to use a "47k resistor-250k pot-47k resistor" instead.  And a 50k output pot.
cheers
Brett Robinson
Moonface
I have read that Krieger used the Maestro Fuzztone...
Paul Marossy
QuoteConcerning that weird 350k pot, I'm going to use a "47k resistor-250k pot-47k resistor" instead.  And a 50k output pot.
Or, you could use a 1M pot with a 470K resistor + 56K resistor wired in parallel with it. That would get you about 347K or so, assuming that your pot measured exactly 1M.
markphaser
Thanks brent
What about the biasing what kind do u think this is?
The output is mixing the in-phase and inverse phase signals ? doesn't this cause cancellation?
brett
Hi
QuoteWhat about the biasing what kind do u think this is?
This biasing system is more common in older circuits.  Instead of supply-to-base and base-to-ground resistors in a voltage-divider, it uses a collector-to-base resistor, and is known as collector feedback biasing.
Common biasing arrangements are described here:
http://203.208.166.84/kawsaralam/biasing.pdf
QuoteThe output is mixing the in-phase and inverse phase signals ? doesn't this cause cancellation?
It probably does a bit, but not so much you'd notice, for two reasons:  Q2 outputs a MUCH larger signal than Q1, so cancellation would happen when a tiny amount of Q2 output is mixed with Q1 output.  Also, the signal out of Q2 has steeper rise and fall and is hard clipped, unlike the fairly normal signal out of Q1.  So they never cancel out very well.
cheers
Brett Robinson
Paul Marossy
Hey fixr1984, where's the second transistor on your vero layout?
fixr1984
Quote from: Paul Marossy on July 22, 2006, 09:12:42 AM
Three holes to the right of Q1
Paul Marossy
Boy, that was a stoopid question! I thought those three pads in the middle of the board was for a transistor and didn't see Q1 and Q2! I was at work doing three things at once when I printed it out. Never mind.  :icon_redface:
