buffered/true bypass
Started by zerohero, July 19, 2006, 10:11:12 PM
zerohero
hey guys, ive been a little confused by something, ive been reading around and trying to learn as much as i can about all this stuff but i cant seem to figure something out.
i understand that true-bypass means that your signal does not go through the effect at all and all that, and that it may cause a volume difference.
i am also getting the idea that because the signal from a guitar is high impedance, it cant push the signal very well, so you can use buffers to help drive it (am i right here?).
so is it better to have true bypass or to have a buffered bypass like a lot of the commercial pedals do? from what i gather most DIY-ers prefer true bypass, if lots of pedals cause tone sucking when bypassed why not use a buffer? sorry if all my ignorance is showing lol, id just rather understand the things i build instead of just putting things where im told (as i have seen all of you here prefer).
  Comparing your effects chains/cables ability to carry signal can be as easy as using a good/great 'shorter' cable to connect your guitar directly to your amp. Then insert the effects chain, if yours is like mine, you'll hear a volume drop with high end content muddled or missing. Or inserting a buffer at the beginning of the chain.
  One buffer or buffered bypass pedal at the beginning of the chain [~same thing as far as buffering]...if your cables are decent at all, should restore the ability of the amp to recieve the 'unaffected' guitar signal and it's highs.
zerohero
thank you sir. much appreciated
amz-fx
Quote from: zerohero on July 19, 2006, 10:11:12 PM
http://www.muzique.com/lab/truebypass.htm
regards, Jack
jimbob
Great article Jack- Even simple enough for me to understand.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
