R.G.'s Parametric EQ Layout
Started by QSQCaito, July 20, 2006, 06:01:14 PM
QSQCaito
no kidding, its me again :P Hihi im here now... not to ask rg's layout, cause i've done it myself;)  As the one who offered the layout wasn't answeing the PM, i decided to layout it myself.. So, here's the result, for some reason when i rendered it the ground disappeared so i redrew it in paint, with some pots..
So if anyone sees any mistake, and/or wishes to check it please, because this is my first layout ever, i searched for mistakes but there's probably one i havent seen.. well, lets check it out, i'll build it later and make some samples :D Here's the link to the schem: http://www.geofex.com/Article_Folders/EQs/parmet.gif
After all the corrections, and maybe some improvement to reduce space, or something you suggest, ill put the final render, to press n peel.. permanent marker to me :(
Bye bye, hope it's useful for someone else..
Diego Andrés Cao
PS Excuse my english
D.A.C
Morocotopo
Hmmmm, that would be me...... :icon_redface: :icon_redface: :icon_redface:
sorry, I don´t log in that often, never noticed the message. I have the PCB file, built it, works OK, a bit limited in freq range with the stock values. Can´t send it to you now, have to go, I´ll send it tomorrow, and answer your questions in detail.
Sos Argentino, me parece haber leido en algun lado? Yo tambien...
Morocotopo
Morocotopo
QSQCaito
uhh que divertido.. sisi soy argentino jaja ;)
No te hagas problema, por lo del pcb, asi al menos aprendo algo jaja, igual si lo tenes asi comparo y veo cual ta mejor..
copado, gracias por las preguntas, no hay apuro, tomate tu tiempo
capaz dps te mande un PM con algunas preguntas a ver donde compras un par de cosas,,
saludos!
y vamos argentina carajo!
jaja
Bye bye
Diego Andrés Cao
D.A.C
Cliff Schecht
Yu judosit lupatid, ouy sorhs vuileho ut ohdge!!!
QSQCaito
Quote from: Cliff Schecht on July 20, 2006, 09:25:25 PM
MM.. stratophonic :S
What's that language(excuse my ignorance)??
Is it what is it, i don't nuderstand, sry
Bye bye!!
Diego Andrés Cao
D.A.C
QSQCaito
Oh, i forgot about something important, do i need RG's permission to post a lyout done of his schematic??
thanks...
bye bye
Diego Andrés Cao
PS I'll be revising the circuit today with my dad i think, and then i'll breadboard and all that, and then tell you the results!
D.A.C
