Jfet matching problems
Started by oldrocker, July 31, 2006, 07:11:20 PM
oldrocker
I've searched for past messages on this subject but I still don't understand this setup.  What opamp should I use here?  I tried a 741.  When I measure voltage at (pins + & -)  I get 4.47v.  It doesn't matter if there's a transitor plugged in it or not. At this point I don't think anything in the circuit does anything to this voltage.  What size cap should I use here?  I'm seeing a range from 10uF to 47uF.  I used a 47uF.  I'm testing 2N5952's for a P-45.  I have 12 of them.  Looks like a simple circuit (Improved JFET Matching) but I'm not doing something right here.
Seljer
I used a TL071 and a 22uF since they were the first thigns I found, following the article on Geofex. Worked fine for all the 2n5952s, 2n5485s and 2n5457s I had. Out of the 14 2n5952s I had I managed to get 2 precisely matched ones for a Phase 45.
oldrocker
#2
Thanks Seljer,  I realized after your response that I needed to use a different IC.  I took out the 741 (ooops) and installed a TL082 and it seems to be working now thanks.
stm
JFET characterization for matching can be easily done as described here (one 9V battery, one digital voltmeter and two resistors is all you need):
http://www.runoffgroove.com/fetzervalve.html#11
