pnp fuzzface bias
Started by lowstar, August 07, 2006, 12:07:28 PM
lowstar
hi everybody,
i recently built a pnp fuzz face that i could not get to bias right (4.5) until i used a 50k trim pot instead of 10k.
is this normal ?
i used a pair of ac122, q1~70, q2~110.
any fuzz-face-expert out there who can explain to me ?
cheers,
lowstar
effects built counter: stopped counting at 100
  RG can.
  Check out the DEBUGGING thread.
mac
#2
It depends on transistor leakage and gain. I have 2sd352 that bias at 12 - 15K and 2n388 that bias lower, 5 - 8k like silicons.
download this (if you get strange results swap the decimal separator "." to "," or viceversa)
http://geocities.com/guitarfxs/exes/FuzzFaceBias.zip
mac
lowstar
hey, thanks !  ;D
the ac122 i use are not that good...that´s probably the reason...too much leakage.
cheers,
lowstar
Stephen
YOU also need to sound good too..
Biasing puts it in range but a higher voltage reading sometimes sounds better.....I am no means an expert this is garage ENGINEERING :icon_redface:
Dai H.
thx mac, that is very neat!  :icon_biggrin:
