RedBox repair
Started by Ken1, August 07, 2006, 04:29:26 PM
Paul Marossy
Quoteyou also mention ... C3 .. and the IC ... are those hard to find items ?
The caps should be fairly easy to find. I don't think that the TL064 will be easy to find. www.mouser.com probably has those. You could also use a TL074 if you can't round up a TL064.
zpyder
Quote from: Ken1 on August 12, 2006, 08:17:28 AM
The IC, which is apparently a TL064, can be found at smallbear at http://www.smallbearelec.com/Detail.bok?no=197
As for C3, I can't read that schematic...
GILLES/Anybody: Do you know what C3 says there on that schematic??  "22m"???
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
Quote from: zpyder on August 14, 2006, 02:32:27 PM
zpyder
It's 22n which is 0.022uF
zpyder
Well then there you go Ken1, if you want to get C3, it's here: http://www.smallbearelec.com/Detail.bok?no=162    make sure to select .022mF
cheers
zpyder
