Microamp build pop's
Started by Theo, August 11, 2006, 05:33:34 AM
Theo
Hi
I've just built a GeneralGuitarGadgets ver. Microamp that sounds good but it pops when i switch..
but looking at the schematic theres already an input pop resistor, isnt there?
What can i do to eliminate the pop?
Theo
George Giblet
Make sure you have the output cap in the right way.
Try replacing the input cap (use a polyester/greencap  type).
j.frad
does it have the 1M ohm resistors at input and output? those are supposed to reduce popping...
freak scene
when using a pull down, will it work correctly if you just place it between the tip and sleeve of the input/output jacks?
Seljer
Quote from: freak scene on August 14, 2006, 09:02:08 AM
nope, you need it between the bypass switch and the input of the circuit.
