Uglyface Build Report + PCB Layout
Started by mydementia, August 13, 2006, 10:19:15 AM
mydementia
Hi guys.
I've been at this for about 8 months and keep hearing about Tim's Uglyface.  I finally decided to build one and am quite entertained!  I put together the layout/PCB below and perfed it up (10x20 holes).  I assumed linear pots throughout...but built with some log (what I had).  I also socketed the Vactrol so I could try different opto-isolator combos (I only have one VTL5C3 and need to make another trem lune...).  I also used RadioShack LM386 and 555CN IC's.
As I'm sure most of you have read, this thing makes some strange noises!  From gross mean fuzz to old 8-bit Atari sounding stuff - quite fun.  I'm not sure if I'll box it up...but I just had to build one.
PCB: http://www.freewebs.com/mydementia/DIY%5FStompboxes/Uglyface/UglyFacePNP.gif
Enjoy.
Mike
ildar
I see 2 pads for V+. Are you using two batteries?
mydementia
Nope - just needed to add a jumper from the +9V source.
ildar
Gotcha.
Another question-you spec a 1n4001 (as a protection diode I assume), will an LED or 1n914 work there?
mydementia
mongo
I'm starting to build this and I have a doubt!
in the layout above, from R2 to the F2 connection there is a blue jumper, but it "touches"  one of the C6 end  as well, is this right? or it's just a jumper from R2 to F2?
thks in advance,
Andy
mydementia
Looks like the lower jumper goes to the upper C6 junction and the upper jumper goes to the IC2 pin 3/F2 junction.  Just use a piece of jacketed wire for the upper jumper so it doesn't 'touch' the C6 junction.
Haven't looked at this one in a while...but I think that's right.
Mike
mongo
Thanks  That's a mistake I was going to make for sure!
Andy
mongo
sorry I'm  such a pain, I still have some questions about this circuit...
I dont quite get some of the wiring...
   V2 goes to ground?
do I put a jumper to rely the  two +9V?
so both input and output jacks are mono?
Thaks in advance for  your help!
Andy
ildar
V2 goes to output.
Yes, you will need a jumper for 9V+
You can use a stereo jack for input, wire it in the standard fashion.
ildar
BTW, thank you mydementia for your help with my build. I built mine using your PCB layout, and I love it!
This is a must-build for everyine, if just for shits and giggles.
mydementia
ildar - glad you like it.
I'm glad I could give something back to this community that's given me so much!!
How's it coming mongo?
Mike
MikeH
If you really wanted this thing to get crazy, you could probably utilize pin 7 on the 386 to make some crazy oscillation noises, a la Parallel Universe style.
mongo
Quote from: mydementia on November 03, 2006, 10:33:40 AM
Mike
sucess!!!
  squeakings, squealings, blips blops and fuzzzzzz!!!!! I love it! I think I will rename mine "8bit fuzz" when I put in in a box... :icon_mrgreen:
  this thing makes wonderful sounds, exactly what I expected of it, I'll try it tomorrow with some machine drums and synths...
I wonder if there's a way to adapt the FREQ pot into a volume or expression pedal, I love the tone qualities when I sweeeeep the freq!
Thank you very much everybody (designers for an astounding device,builders, fellow diy'ers) for you help!
Rock on!
Andy
mongo
this is old but I guess it's worth to ask...
I find that my uglyface is LOUD! I have to use it with the volume at 1 or 2,after that it's just too loud,
it is a way to tame the uglyface's output?
Thanks,
Andy
John Lyons
Assuming there are no mistakes in the build you could use a smaller volume pot. Try 50KA or 25KA
John
Basic Audio Pedals
www.basicaudio.net/
b2thea
or put a resistor before the pot :)
i did this with a pvm i built for someone, it helped allot :)
mongo
Quote from: b2thea on January 30, 2007, 10:20:23 AM
  a 25k resistor for instance?  I guess I'll try several measures. thank you for your answers
tiges_ tendres
Quote from: mongo on January 30, 2007, 08:27:21 AM
Thanks,
Andy
Everyone has made the same complaint about loudness.
If it's too loud, you're too old!
Try a little tenderness.
b2thea
in the pwm i built a 100 k resistor in series, before the volume pot...
it was needed, the thing on itself was way to loud
