sleve, ring, and tip?
Started by Snuffy, August 14, 2006, 01:30:15 AM
Snuffy
I'm almost sure that the sleve is the top, the ring is the middle, and the tip is the bottom one (bottom being closest to the enclosure)
Is this right?
Snuffy
Talking about the jack where you plug your cable into
I'm horribly confused  :-[
John Lyons
Don't worry about it. Everyone starts out confused.
Starting with the Plug, which is stereo or 3 conductors:
Tip it the tip of the plug, this is also the Hot or +.
Ring is the Middle section.
Sleeve is the Long metal shaft closest to the Thick body of the plug, and always connected to ground.
The Jack corresponds to the same points. Tip is the outermost "finger" of the jack. The ring is the middle "finger" and ground is the hole that the pluge goes through.
Here's a pic from the smallbear site
Small
John
Basic Audio Pedals
www.basicaudio.net/
Snuffy
Thanks a bunch
I'm lightheaded from all of the soldering
d95err
Quote from: Snuffy on August 14, 2006, 01:30:15 AM
Is this right?
When in doubt, always use your multimeter!
GibsonGM
Plug in a guitar cable and look at the jack...tip is the very tip of the 1/4" plug, ring is the lower conductor below the plastic insulating washer - or "side" of the cable, and sleeve is the threaded part of the jack.  Actually seeing this, and using the DMM to verify which terminal goes to which 'arm' on the jack, really helps! Used to drive me nuts, he he.
