Clean blend on an English Muffin??
Started by Bernardduur, August 16, 2006, 01:31:22 PM
Bernardduur
Hi all!
I just got an English Muffin (EHX) and I love the unit to death...... I have one complaint and that it, as I use it on bass, loses a bit of clear low end. So I wanted to install a simple clean blend....
I tried some ideas (Bblend, resistance blend etc) but all does not work.
What I know:
- The unit is switched by a relais
- Before the volume pot a simple treble / mid / bass control is there
- The unit ends with the volume pot (1M) and a resistor wired in series of 162k that goes into the relais.......
I am a bit out of ideas.......
These
Am learning something new every day here
SquareLight | MySpace account
moosapotamus
What do you mean when you say, "doesn't work"?
I don't work with relays very much. Do you? Are you sure you are tapping in/out in the right spots?
Also, instead of thinking about it as if you're modding the muffin, have you maybe thought of it as though you are modding a bblender... to permanemtly add the muffin to the bblender, as opposed to the other way around?
~ Charlie
moosapotamus.net
