Blue (New) Clipper with diode-Compression Op Amp
Started by 3/4 North, August 20, 2006, 11:10:04 AM
3/4 North
I thought the Clipper would be a good canidate for this op amp since it clips the ic.  But it didn't work.  I breadboard the project twice and could not get any volume let alone distortion. Anyone else try it with the clipper?
Joe
3/4 North
#2
Thanks Joe!
But the third time really is a charm. It's working great!  First I breadboard the Blue Clipper with a 4558 chip and got it working, then pulled the chip and breadboard your op amp in its place.  That op amp sounds amazing, less noisy & smoother sound.
Here's the Blue clipper schem...
...although I used the original 200k and 240k resistors instead of the 22k's.
Since the input is grounded I was wondering about the 1uf cap you recommend adding across the 10k resistor in the op amp. I tried it but it seemed to have no effect. Is it necessary?
I'm going to tweek and perf board it, be back with pictures. :)
Joe
Glad it works now. You don't need the 1uF cap in that circuit, it's non-inverting. It might be a good idea to stick a 5-10pF ceramic between base & collector for stability.
d95err
Quote from: Joe on August 22, 2006, 05:58:05 PM
Which base & collector? On all transistors in the discrete opamp, or?
Joe
3/4 North
Here's a schematic of the Blue Clipper with the op amp.  This is how I built it on the breadboard with an added toggle and gain pot. The toggle is interesting, I can really hear the compression kick in and I get some added sustain when I lower the tone.
Joe, I put the cap you suggested in red, is this where you say it should be?
Because of the way our server is set up I can't see the image, let me know if it doesn't show.
WGTP
Now you'll have to try Joe's alternative diode compression circuit out with it.   :icon_cool:
Stomping Out Sparks & Flames
3/4 North
#9
Quote from: WGTP on August 23, 2006, 12:54:58 PM
http://www.diystompboxes.com/smfforum/index.php?topic=48507.0
Cool, I'll give it a try!
hey Joe, how 'bout drawing up a JFET version of the op amp for us "electrically ungifted"?
Joe
You can use some P-channels with slight tweaking of the 6.8k or 4.7k resistors. I tried inverting the circuit and used J201 inputs/2N5087 output and flipped voltage/diode/electrolytic polarites, and didn't have to change a thing. The problem is that the gain is way too low, and I'm not sure it sounds better. I think a MOSFET discrete opamp is in order, maybe that's coming next?
P.S. R6 should be 6.8k.
3/4 North
Thanks, I fixed the schem
And I thought I'd post the original unmodified Dan Armstrong schematic
I attempted to add a tone control but the toggle on the input cap just wasn't doing it for me.  It went wimpy to muddy.  But the gain pot works well.
This is where I'm at now.
The soft clipping diodes sound good and helps the tone, probably because of the caps.
Not much left of the original clipper.
WGTP
If you want to try tone switching, try doubling or halfing C4, the 4.7uF cap.  That should have lots of effect on the "character".   :icon_cool:
3/4 North
WGTP
Forgot, might jack up R12 150K resistor to 470K, 825K or 1M for more gain, if you need it.   :icon_cool:
3/4 North
This thing has tons of gain and good sustain, that's why I was thinking the JFET op amp would be no problem.
WGTP
Mosfets, BS250's and BS170 should work with resistors tweaked.   :icon_cool:
3/4 North
The 4.7uf cap had no effect on tone, guess I'll perf board it the way it is, unless Joe posts a mosfet version soon...
WGTP
Hmmm.  You should hear a difference, but if the gain isn't maxed, you may not be able too.  I'm such a gain pig, I usually set things up on my bread board without a gain pot.
3/4 North
I did a perf board layout
since these are usually disastrous for me I took an Arts & Crafts approach this time and wove the traces in with copper wire.
Here's a shot of the finished board (with an added 1k resistor to ground off the gain, so it's not so crazy sounding)
And here's the back
It's a good sounding distortion with lots of volume and sustain
