Fuzz picking up overseas radio????
Started by mdc, August 21, 2006, 11:09:02 PM
mdc
I built a fuzz for a friend and when he got it home and plugged it in, he started getting what sounded like radio transmitions from overseas coming through his amp. Any theories as to what might be causing this? It's not really a problem (he thinks it's cool) but it would be interesting to hear some ideas about what is happening here. He recorded a some of the transmitions and emailed it to me. You can listen to it here http://members.dodo.com.au/cowinfamily/files/radio.mp3
Cheers
Guitar FX built: NPN Fuzz Face, PMPU Octavia, A/B box, Univibed Phase 45, Ruby
jonathan perez
yeah, that happens. look it up with the search function.
#2
  10k before the input
  Small cap to ground at input
  Ferrite Beads...let me know if you figure out which type/how it goes..
  Grounded shielded box
  Grounded at one end / [longer] Shielded signal wire/s inside the box.
3  *10k will slightly reduce input gain
2  **Small Cap will roll off a touch of highs [maybe not even noticable/adjust value]
5  I never tried a Ferrite Bead
1  Shielded box...
4  Shielded wires for signal input/output
  Sorry about the order, I'd start with a shielded box, then the small cap [cause it's easy, probably works and has little drawbacks] or the 10k for same reasons, then shielded wires cause they're sort of a hassle.
cakeworks
my mate had that problem with his fuzz face... turned out to be a crappily shielded patch lead
-Jack
Is that a plastic washing basket?
"Actually a Sterilite-branded storage tub.  Rubbermaid has better mojo, but it cost more" - Phaeton
