Milennium Bypass (2N)
Started by mydementia, August 27, 2006, 10:09:23 AM
mydementia
What's the 100k resistor from the effect output to ground doing?  Can I run it across my output jack instead (usually easier)?
Here's the layout/reference I'm using:
http://aronnelson.com/gallery/TheBigMan-Layouts/mb
I read through the geo articles and didn't see mention of this resistor anywhere - maybe I missed it.
Thanks in advance.
Mike
Seljer
http://www.geofex.com/Article_Folders/Millenium/millen.htm
look at the first picture with the "internal DC resistance to ground"
often thats allready there in the form of the volume pot by the output or just as a regular resistor
TheBigMan
Yeah, it's often not needed but I included it for completness.  With most DIY effects there'll be a 1M+ pulldown resistor there anyway.  It is necessary though in things like the TB box that R.G. did with the MB.
cakeworks
Do you reckon this might work for true bypass with an led? Sorry for my crappy drawing!
-Jack
Is that a plastic washing basket?
"Actually a Sterilite-branded storage tub.  Rubbermaid has better mojo, but it cost more" - Phaeton
Seljer
Nope, as the input impedance of the effect board is always present, even when bypassed, so no true bypass
For the Millenium bypass deal you have to wire it up something like this: http://www.generalguitargadgets.com/diagrams/switch_lo_dpdt_mil.gif
read the bypassing and Millenium bypass arcticle on geofex, lots of good info
http://www.geofex.com/Article_Folders/bypass/bypass.htm
