+ gnd and - gnd in the same enclosure?
Started by powerplayj, August 27, 2006, 02:18:23 PM
powerplayj
Can't be done can it?  Thought about pairing my vibe and PNP pos gnd fuzz face but unless I change the grounding of the fuzz and risk the potential for oscillations I assume it isn't possible.
Does this mean the Captain Coconut has a neg gnd fuzz?
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
Of course it can be done.
You need two independent power supplies, one +9V and one -9V. Then they can share a ground. The one ground is then both a negative ground to the +9V and a positive ground to the -9V.
powerplayj
Then I'm back in business!!!  Separate power supllies is not an issue since the 69 Fuzz will have a battery and the Vibe (once I'm satisfies with the tuning) will have a DC adapter going into a charge pump.  Thanks......
next build(s): ???
