Discrete Tubescreamer
Started by g3rmanium, August 28, 2006, 01:44:02 PM
g3rmanium
Hello,
I'm looking for a discrete, simple Tubescreamer-sounding circuit. I have an Arion Tubulator and the sound into my Green Ringer is great. I'd just like to replicate the Tubulator-Green-Ringer-chain without all the opamp stuff (and less parts ;D ).
I built an Electra Distortion sometimes but maybe there are other options.
Thanks.
Call me Johann.
WGTP
Check out the search funtion, there are a number of threads about Discrete Op Amps.  Also look at the diode compression section.  Here is something you might find helpful.   :icon_cool:
http://www.diystompboxes.com/pedals/schems/Shaka%20Discrete.pdf
Stomping Out Sparks & Flames
g3rmanium
Quote from: WGTP on August 28, 2006, 02:11:31 PM
Thanks, but I'm not looking for discrete opamps, just for a circuit that is simple but sounds similar.
Call me Johann.
Seljer
never built one but its described as a Tube screamer alternative
http://runoffgroove.com/odie.html
burnt fingers
My guess is you'll end up with more parts if your trying to replicate a TS using only discreet devices.  Try the Runoff grooove Tube reamer or tube reamer v2.  It uses an opamp but it has a small parts count and is very easy.  It sounds good too.
Scott
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
petemoore
#6
  I saw a schematic for one once.
 It was an opamp internal schematic built on a board using transistors...something like 32 components for 1 x OA...
 The Tube Screamer [everything except the OpampS], IIRC was part of the same board as the 'enlarged' version of the discrete opamps.
 So I guess it was just a matter of incorporating the opamp [internals] schematics into the board with TS circuit 'tacked on'.
  ...Then trying it, maybe having to watch the layout...probably 3 or 4x the size of a 'TS'....guessing of course...
g3rmanium
Quote from: burnt fingers on August 28, 2006, 03:03:04 PM
I'm not trying to emulate a TS, I just want something simple that sounds similar. Thanks for the links though.
Call me Johann.
WGTP
http://runoffgroove.com/peppermill.html
Sorry for the misunderstanding.  Might check this out too.   :icon_cool:
Joe
This sounds kinda like a TS9 when using a high-gain transistor (like the 2N5089):
http://www.diystompboxes.com/analogalchemy/pedals/easydrive.html
g3rmanium
Quote from: Joe on August 28, 2006, 07:11:37 PM
Thanks, that looks easy enough ;D
Call me Johann.
Gilles C
I am wondering about "A Touch Of Sweetness" from Jay Doyle.
http://www.diystompboxes.com/pedals/schems/Sweetness.pdf
I should check it. This one is still boxed, because I remember I liked it in my SRV years.
Gilles
blanik
are there any soundclips for the Easy Drive somewhere, this one looks so simple, i'm curious to ear it!
R.
