Ross trim pot question
Started by jimbob, August 29, 2006, 01:34:01 PM
jimbob
QuoteQ. How to set the trimpot?
A. Set the trimpot in the middle, slowly turn it to both sides while letting single notes ring. Leave it in a position where the decay doesn't sound gated.
What I dont understand is that it doesnt seem to make a difference which way I turn it. It still sounds the same. Is it just me? Or could it be a bad trim pot?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
markm
Play a note and let it fade, listen then for gating and adjust it to where the note fades naturally and there is no gating in the signal.
jimbob
Thats the problem. I dont hear any gating at all. Actually sound fine. NOt that that is the problem. I just wanted to make sure it was working right.
Jay Doyle
It should make a difference as you turn the trim. Is the effect working otherwise? Do you get a long sustain and plenty of compression with the controls maxxed?
jimbob
Yup- getting both the sustain and the compression
Jay Doyle
Well..........Um..........I don't know what to say. :icon_eek:
If you like the sound of the effect and it appears to be working......... I don't know. I say go with it! :)
Roberto
This is the calibration proceture:
Input signal 2KHz 5mV
Turn sustain and output controls CW. Connect test probe to CA3080 pin 6 (out). Adjust bias trim pot for 2.5Vdc in pin 6.
Turn sustain control CCW. Turn output control CW. As sustain control is turned CW, bias voltage should not vary more than 100mV.
markm
Quote from: Roberto on August 29, 2006, 06:41:28 PM
Interesting.
First I've heard of a non-by ear setup.
