Cornish "money pedal"
Started by g.e.o, September 03, 2006, 08:34:01 PM
g.e.o
hi everyone. am interested in knowing what exactly is the money pedal pete cornish made for david gilmour. he says its a "Vib" pedal. what exactly is it? thanx in advance!
George
boogietube
Vibrato is what it sounds like to me. Many Fender amps at that time had tube Vibrato circuitry in them. I think it more likely that he's using the Vibrato on a fender amp. If you want that vibrato sound in a pedal, the only place that I'm aware of (DIY)  is here:
http://www.buildyourownclone.com/vibrato.html
Hope this helps
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
It may also be leslie rotating speakers. Univibe is an available pedal that simulates this. I poured through some net stuff and came up with this link:
http://web.tampabay.rr.com/richm/sbarchive.htm
Satch12879
Gimour's been using the Demeter Tremulator for more than a decade now.
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
boogietube
Ya but he didn't use it in 1973.
Seljer
g.e.o
thanx to all for the help! i too think its a vibrato pedal but it was made on a cry baby's body. something tells me its a mix of wah/vibrato or something. i checked all the possible links including the ones u suggested and doesnt say what kind of pedal this was. still a mistery. think i may ask cornish for as all! ;)
tiges_ tendres
Quote from: g.e.o on September 05, 2006, 07:48:23 PM
its probably vibrato, with the speed being controlled by the wah pot.  No wahing though I'd guess, not in the same pedal.
Try a little tenderness.
boogietube
The univibe is what he used live if you read the equipment links (at certain time periods) It was very interesting to read!
There's a neovibe at GGG. That goes into detail about the volume pedal as a controller. I'm not there in my building skill yet.
Here's a link to the Dunlop Univibe site :
http://www.jimdunlop.com/index.php?page=products/pip&id=282&pmh=products/p_and_e_detail
Notice that there's an optional UV-1FC controller pedal that you can plug into it to control the speed.
That would do the trick! Expensive!!
Sean
g.e.o
hey sean! thanx for the thought and help but am awared of that. its not the univibe. its as cornish himself says a vib pedal known as the money pedal and i tend to believe its just a controler for the amps vibrato as tiges tendres also said. anyway thanx a lot!
George
