What is a DB01?
Started by Fleetdog, September 05, 2006, 12:13:42 AM
Fleetdog
I'm looking at the spyder design (http://www.geofex.com/Article_Folders/Spyder/spyder.htm) and I see there is a DB01 chip across each transformer (or pair from the weber trans).  What is it?  I didn't find them looking at Mouser, Digikey, or just on Google.
fixr1984
Click Here
I did a search and found this. Scroll down to R.G's reply.
Hope that helps.
Fleetdog
You know I searched for spyder posts and read several but missed that one.  I should have searched here for DB01.  Thanks.  That was just the info I needed.
lapbarbosa
It's a diode bridge used to rectify AC current. You can use 4 1N4001 diodes instead.
Gilles C
#4
I used a W06G bridge for mine. I was looking for the cheaper and smaller in store.
http://www.ortodoxism.ro/datasheets/GeneralSemiconductor/mXqqvtq.pdf
Gilles
