12AX7
Started by zpyder, September 06, 2006, 12:31:06 PM
zpyder
I realized last night that I have an unused, 5 year old 12AX7 collecting dust at my house... it came from a Fender Hot Rod Deluxe that was stolen from me years back.
Anyone know of any schematics that could utilize this tube?
cheers,
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
Seljer
Most of the tube based distortions/overdrive that are around use regular 12AX7s, the Shaka Tube or the Tube Driver or the Real McTube. (I believe the first 2 only run on low voltages fed by 12VAC. The McTube has got another transformer that turns the 12V back up a hundred and something for use with the tubes)
ildar
I've been kicking around the idea of building a tube-based pedal, but really want a higher-voltage circuit. However, I'm leery of tubes because of the potential rip-yourself-a-new-one factor. What is the safety/difficulty level of the McTube?
JimRayden
Quote from: Seljer on September 06, 2006, 12:40:19 PM
The latter two also don't sound too good. The Tube Driver doesn't overdrive the tube itself but instead uses opamps for this and uses the tube for "warming up" the signal in the end of the chain. At 12V. Real Mctube, although at high voltage, is just a fuzzy-sounding circuit. It can be modded into a pretty decent overdrive though (search the ax84.com forums). Shaka tube, according to the clips I've heard is an excellent sounding circuit which runs at 24V, which is what I'd like to call semi-starved plate design.
From the above three, I'd choose the Shaka. Just go and listen to the clips at the schematic section. Sweet.
Jimbo
JimRayden
If you dare, you might also try the Marshall preamp project:
http://www.hoffmanamps.com/projects/tube_box.htm
http://www.hoffmanamps.com/projects/images/TubePedalSchematic.gif
The sound clips (somewhere in that quite extensive webpage) are pretty darn good.
Jimbo
puretube
these "H*ffm*n boxes look cute!  :icon_mrgreen:  :icon_wink:
doesn`t/didn`t Aron sell these, too?
as well as those toroidals?
The Tone God
If you are will to get another 12AX7 you can build a Bullitt. Nice boaster and tremolo. /self-promotion
Andrew
andy123
Hi,
Are there any clips of the bullitt anywhere? the search didn't show any....
Cheers
Andy
The Tone God
Quote from: andy123 on September 06, 2006, 03:31:43 PM
No I didn't do any and I don't know if anyone else has. I'll try to do a few the next time I'm doing samples.
Andrew
aron
Quotedoesn`t/didn`t Aron sell these, too?
yes, I still have both if anyone wants.
Aron
boogietube
The wickedest project that I've seen is this one:
It's the Shaka Tube in a Hammond box project on this site:
http://diyguitarist.com/
This guy kicks butt!!
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
