Making A Dual Opamp
Started by Shannon, September 08, 2006, 06:48:50 AM
Shannon
Hey guys, first post around here. I'm thinking of building one of these DC opamps and squeezing it into my DS-1. Only problem is  my DS-1 uses the Mitsubishi M5223AL dual opamp. How would one go about making this a dual opamp? Would I simply build two and connect -ve and +ve together?
Thanks. :)
3/4 North
Yep, and it works.  I did that for the bluesbreaker, my post with some pictures: http://www.diystompboxes.com/smfforum/index.php?topic=43635.0
chicane02
FYI-
Just in case you wanted to try a pre-made op-amp, here are two that work well, I happen to know...
This is assuming you have the SIP-8 op-amp in your DS-1.
NJM2904
NJM3404A
These are drop-in replacements for the Mitsubishi M5223AL
