Where to find 150K Dual A Pot?
Started by A.J., September 09, 2006, 02:14:42 PM
A.J.
Hi All;
Starting to get the parts together to build the Maestro Ring Mod on GGG - can't seem to find a 150K Dual Audio Pot at any of the regular sources - anyone know where to track one down?
Thanks,
A.J.
John Lyons
I just used a 100K Dual Audio in my Maestro Ring mod. The Pot in question is an input level control so it shouldnt make too much difference.
You can always add a 50k resistor to the top of bottom of the pot if you want to try the 150K in the schematic.
Mine seems fine with 100k. Unless you want more level (less than all the way up or off) then 100k seems fine...
I had trouble getting the power supply caps to fit on the tiny power board at GGG. I posted a Larger PCB I made if you are interested. Just search for Maestro RM-1 here and it will come up.
John
Basic Audio Pedals
www.basicaudio.net/
A.J.
I sort of figured that that's what I would have to do - I'll will check out your PCB, however - thanks, John.
A.J.
