Phuncgnosis mods
Started by mac, September 09, 2006, 07:03:30 PM
mac
Or see the EHX Bass Balls
mac
the noise seems to be related to the down mod. I'll record a passage later and post it up.
heres a sample
note in the recording i turned the mic pre up a fair bit for a start (before i play) and fiddle with the guitar volume pot so you can hear the effect)
the noise i dont like is the little decay noise (sounds like ripple to my ears but i could be wrong) after the chords are played.
Kinda spoils the nice wah ing.
Im certain its related to the transistor 470uf cap mod.
It dissapears when i remove the transistor (mind you so does the wah)
i tried a led in the place of the transistor . same thing . Schucks.
i tried moving the r13 it stopped wahing
i removed R13 it wahs but i still have the noise.
so i put it back as per Robs Schematic.
https://www.dropbox.com/sh/7ma9n53c5jqdgsr/9i7Vk6rKwg/Phuncgnosis%20example%201.mp3
mac
#44
What makes the ripple is the envelope detector. You can use bigger caps C3, C4 at the detector to minimize ripple, like in a power supply, but you'll increase the decay time...
There was a nice explanation about how the fretboard vibration, even a fly over the breadboard can introduce noise into the envolope follower. If I could remember who wrote it...  >:(
QuoteSo just to clarify since the schemo isnt numbered
This bit?
inside the  red
https://www.dropbox.com/sh/7ma9n53c5jqdgsr/d-0TvwYXDL#lh:null-Phozer%20mark%20up.JPG
thanks
Yeap. Now you need to do the same with Rob's schematic  ;D
mac
i've soldered in 2x 4u7 for c3 and c4 and it does nothing to get rid of the ripple.
the ripple is coming from the transistor everytime i remove it the ripple goes away. It doesnt wah anymore after the trannies removed even with the switch in the up position which i find odd.
theres still some room on my perfboard so i might try your suggestion later but i'd really like to get rid of the ripple first.
I noticed Jimi did a daughter board mod and his work. whats going on?
Freppo
Hi folks,
I just want to share a vero layout I did which includes the mods by Dead Astronaut and small enough to easily fit a 1590B.  :)
However, I can't get the down mode working at all, so I would appreciate if anyone can have a look at it.
The up mode works fine and it sounds nice. I tried breadboarding the circuit with the same result. :/
The only things I've added are a 5817 for reverse polarity protection and a 100uF cap between V+ and ground
cheers
/ Freppo
Check out my building blog at www.parasitstudio.se
mac
Quotei've soldered in 2x 4u7 for c3 and c4 and it does nothing to get rid of the ripple.
Rich,
I missed your last post.
I was experimenting with transistors as variable resistors in another autowahs, and I had ripple issues. I tried different transistors and gain until I found a good one.
mac
Thanks Mac
When I'm done hacking this envelope filter hacked wah of mine I'll try some differant trannys
cheers
mac
Someone younger, eagle eyed, to verify Freppo's vero?  :(
mac
sounds like freppo didn't get it working on breadboard too...hmmmm
so that may be the problem...i just can't get my head around vero layouts.. :)
well, I'm late to the party. I looked at freppo's layout (without the mods circuit), and I obviously got stuck at "the" 2n3904.
so, rob, can you do some voltage measures on that transistor, just for shinys and giblets? THEN we can compare some .....
I couldn't see anything dogsballing on the vero, freppo.
" I will say no more "
i haven't got that pedal now..
sorry.. :)
Freppo
Quote from: duck_arse on July 11, 2014, 08:46:37 AM
Thanks! I'm away on vacation for a couple of weeks so I will pick up this  project again when I get home.
Perhaps I'll just omit the down mode..
cheers / Freppo
just for me, freppo, when you gets home, can you try shifting the switched connection from the C to the B, and leave C open? or anyone w/ this on the bredboard?
don't bother, it don't work the way I was thinking. which was along the lines mentioned here:
http://www.diystompboxes.com/smfforum/index.php?topic=106637.msg965491#msg965491
I was hacking about trying to get the E-B connections to work, and managed to smoke-emit one of my favourite pots. eau-de-roland, peee-uww.
Freppo
Digging up this old thread again.
Still no luck with the down mode. So I decided to omit it from my vero layout.
I like few controls on a pedal anyway. :) The finished and verified vero can be found at:
http://parasitstudio.weebly.com/stripboard-layouts/phuncgnosis-auto-wah
It's a nice sounding simple auto wah. I'm going to box mine soon. :)
Cheers / Fredrik
