1n60 as a clipping diode instead of 1n34A???
Started by bancika, September 12, 2006, 11:12:45 AM
bancika
Can 1n60 substitute 1n34A as germanium clipping diode with similar results? That's the only GE diode they have around here.
Tnx
D Wagner
Yes!  The 1N60 is a great clipping diode.  The MXR Distortion+, or the DOD Overdrive 250 sound perfect with them.
I doubt even the "golden ears" could hear a difference between 1N60, 1N34A, and 1N270 (what was originally in the Dist+ and any other MXR pedals needing GE diodes).
bancika
that's great  :icon_mrgreen: for two reasons
1) I already got 1N60 and they weren't cheap (about .70$ each)
2) the only way to get 1N34A for me is to order from internet and then wait long and pay customs expenses
Thanks guys!
mac
My ears are not in good shape but I can certainly hear a subtle difference between 1n34, 1n60, oa91 and aa117 in a MXR+...
mac
mjones99
I think the 1n60 sounds a bit more wooly than the 1n34a and quite a bit more wooly than the 1n270 to me anyway
JimRayden
Quote from: mac on September 12, 2006, 10:04:55 PM
mac
Have you tried listening to two 1N34 pairs? Might give the same difference.
Jimbo
LP Hovercraft
The owners of the cool electronics store out here in Denver tells me that the 1N60 is fuctionally the same, but manufactured to tighter tolerances than the 1N34.  These guys are way into homemade crystal radios and say they are superior in that application.  I found a matched quad for a ring mod I am making, no problem-only had to buy 10 of them.
TheBigMan
Most people use 1N34As cos they are the most easily available germanium signal diodes.  Using something else is certainly not a crime though!
mac
Differences between pairs of 1n34s? Sound like tolerance variations between capacitors. Mine are from the same batch, I never paid much attn but I am going to try different pairs.
IMO, one can use any diode or mix different diodes, it is a matter of personal taste. 1n34, 1n270, 1n60 , Si they all sound good.
My mxr+ has selectable 1n60 and 1n4148.
mac
Eb7+9
Quote from: bancika on September 12, 2006, 11:12:45 AM
... that's the only GE diode they have around here.
It should be pointed out that Point-Contact Ge diodes are not really Germanium diodes in the strict theoretical sense - ie., where the forward "on" voltage (Vf) would lie around 200mv ... if you read the datasheet carefully on these you'll notice both these guys don't have published Vf specs, only a max spec - which is stated in both cases as 1volt ... my 1n34a's and 1n60's measure around 300mV at around 5mA forward current ... if you want a real 200mV GE diode you should grab the BE junction of a Ge transistor - this makes a difference in LFO waveshaping circuits - of course, that's not really crucial for clipping functions ...
~jc
mac
WGTP
Seems like someone around hear thought one or the other had more bass. :icon_cool:
Stomping Out Sparks & Flames
