Reverse engineering technical question
Started by hilbi, September 13, 2006, 04:35:52 AM
hilbi
I am reverse engineering a certain overdrive pedal, i don't have they actual pedal, i'm trying to copy it from some foto's I have. Now i'm seeing a 10K resistor connected from +9V to pin 5 off the jrc4558 opamp. Now my question is if this technically is ok?
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
bancika
Alex C
petemoore
Now i'm *seeing a 10K resistor connected from +9V to pin 5 off the jrc4558 opamp. Now my question is if this technically is ok?
  If it works...I haven't seen the schematic lately, perhaps there's another resistor keeping pin 5 from being pulled up near +9v, or there's some reason for a 'wierd' bias with this circuit, 10k to V_ or + supply would= strong pull on the idle bias.
  Seeing isn't believing.
  Test that with a DMM !! 1 or two probes [Beep mode] from the 10k's leg to the questionable connection and you'll probably be able to verify where it's connected...
hilbi
yes it is a ts variant, i saw indeed that the real ts has a 10k to 4,5 v, but should it harm if in this case it is connected to 9V?
The arrangement around the 22uF is also a bit different.
I'm abit hesitating with posting a pic,'I don't want to ran into legal and ethical issues. Maybe I will post a part of the circuit for questions and technical discussion.
hilbi
hilbi
There is indeed another 10k resistor connected to pin5 and to ground. So this is probably a voltage diveder correct?
hilbi
George Giblet
theman
Yep ... this is the 10K/10K divider which sets up the VREF voltage which is half the supply. There should also be an electrolytic cap hanging somewhere off the VREF node also -- probably 47 uF. If it's a TS variant and there's input and output buffer transistors, you'll probably see 510K resistors connected between VREF and the base of the NPNs.
hilbi
there is a 22uF cap connected from pin 5 Vr to ground.
no in and output buffers.
hilbi
theman
Quote from: hilbi on September 13, 2006, 04:40:01 PM
this is probably fine ... sounds like a ts variant with no input and output transistors -- which sounds like a lot of other boutique pedals ...   :icon_biggrin:
aron
