Glue on metal question
Started by csmatt45, September 14, 2006, 03:53:34 PM
csmatt45
Hey folks,
Can anyone recommend a god way to glue a small photo onto a stomp box? It can't be hot glue or epoxy because I need it to be as flat and smooth as possible. I'm thinking maybe scuff the finish with 220 sand paper, then use good old elmers glue, thinned out a bit.
Any other reccomendations?
DIY forum rules! thanks,
Matt
Seljer
Spray adhesive would probably the best for getting a nice thin enough uniform coating
lumpymusic
Quote from: Seljer on September 14, 2006, 04:01:51 PM
I have used 3M Super 77 spray contact adhesive very successfully.
Lumpy
In Your Ears for 40 Years
www.lumpymusic.com
redeffect
Vote #3 for spray contact adhesive.
csmatt45
do you think I'll need to scuff with the sandpaper?
thanks,
matt
vortex
I'd say Yes, scuff up the enclosure first. Most enclosures have some kind of oily coating on them which can't be good for adhesion. Even if the box is free from oils it's a good idea to prep the surface with a bit of sanding. 120 grit would be good.
petemoore
  Nail polish remover [..acetone] and a paper towel gets the last traces of oil off.
  *Scuffing and/or chemically removing the oil should allow excellent adhesion.
MikeH
You could always print the photo out on some photo-quality waterslide decal paper for laser jet.  Once you get the technique down, you can make some pretty professional looking graphics.  I've even made some very convincing graphics with the inkjet paper too.
Pushtone
I've use clear coat spray to glue on plain old office paper.
I print on clear or bond with a color inkjet.
I clear coat the printout first and let dry overnight.
Then I spray a light coat of clear on the box top only.
Then stick the paper down on the wet box.
You can reposition for several minutes.
Let dry for an hour.
Then 5 to 6 coats of clear to encapsulate the label.
Works great with bond office paper and it's thinner than photo quality paper.
Elmer's glue mixed with water should work too by why bother? Just use the clear as glue
csmatt45
GOT THE SPRAY ADHESIVE, WORKED GREAT. THANKS FOLKS!
MATT
