How can I flatten the "midrange hump" on a tube screamer ??
Started by ChrisGS, September 16, 2006, 07:42:27 AM
ChrisGS
Hi Everybody ,
This is my first post...I was reading a few different Tube Screamer articles on the web , and I decided to start experimenting .
The pedal in question is a Maxon OD808 , which as I understand isn't exactly an 808 schematic , but closer to a TS10 . Anyway , as is I like the smoothness of the distortion quality , but I wish the pedal had a more natural EQ .
I changed the .047uf cap at the input of the op-amp to the recomended .1uf cap for increased bass , and I think it did increase some bass but the pedal still has the "midrange hump".
I'd like to try some things to get a more natural EQ...Are there any things that can be done to "fix" the midrange hump ?
Thanks for any advice ,
Chris .
MetalGod
From my experiences with TS-808s and SD-1s I'd say its the 0.047uF cap from the non-inverting input of the 4558 that needs to be altered to get rid of the midrange hump.
Try a 0.1uF cap and you should be good to go.
:icon_twisted:
donald stringer
troublerat
See "The Technology of the Tube Screamer" at GEO for why it's got a hump. Then un-restrict it, using the article as a guide.
JHS
Maybe a twin-T filter between the stages would be helpful, or raising the lows and highs, or a mid-trimpot wired like in the Barber DD.
There are a lot of other ways to reduce the mids. The best way to start is to build a clone on a breadboard (w/o buffers and the front end booster stage) and to try out every mod.
JHS
markm
Quote from: JHS on September 16, 2006, 10:00:56 AM
JHS
Question?
What is the benefit without the buffers on the circuit?
Are they neccessary to have? I have been thinking of building one w/out the buffers but was wondering what effect it would have.
Seljer
Quote from: markm on September 16, 2006, 12:13:16 PM
Question?
well the TubeReamer over on runoffgroove took them out and still works pretty well. I'm not sure if the input one has a huge effect but doesn't that output buffer do some magic in regarding how well it drives your amp?
Urso
Try this (inspired by the Full-Drive 2):
Tested on an Ibanez TS808 RI, and it sounds *very* good ;)
ChrisGS
Hi Everybody ,
Thanks for all of the replies...Of course some of the answers lead me to new questions ...Such as , what's a twin T filter ,and is there a schematic around for a DirectDrive ? (I did not know that it is in the Tubescreamer family)
Also , I changed the .047 cap that connects to the chip (pin 2 ?) with a .1 cap , and I believe that it did help the bass ( One of the mods listed in the Technology of the Tube Screamer) but I was wondering if there is a point where increasing the size of the cap may muddy -up the sound.
And also , I like that article link for the frequency cut-off for the input cap , and the Fulldrive 2 schematic .
Thanks again for all the help ,
Chris.
ubersam
Quote from: R.G. on September 16, 2006, 09:26:30 AM
Thanks for that article R.G. I refered to that article when I modded my buddy's TS9, it also got me started on my first DIY FX project.
Anyway, since I changed the resistor in the highpass filter to 1.5k, for more gain, I changed the cap to .22uf to bring the knee to 321Hz. I've brought it down to 193Hz and I think that was too muddy for my taste, specially at higher gain settings. I did the calculations the hard way, by hand, not knowing that there is an easier method here -> http://www.muzique.com/schem/filter.htm, thanks to Mr. Jack Orman.
