[HELP] Arion Sad-1 Problem
Started by HeaD, September 16, 2006, 09:54:48 AM
HeaD
Hi all,
I've a problem with a SAD-1 of mine (I got 2). When I stomp, the LED light on but the effect does not work, the sound is unaltered. I've done a search and have found a post with the same problem, there is also the schematics:
http://www.diystompboxes.com/smfforum/index.php?topic=44923.0
Initially, I've also thought to the flipflop/fet, but I've checked ALL pins voltages, and are the same of the other pedal.
I don't understand... does someone have any ideas? Thanks.
Sorry for my english :|
Paul Marossy
HeaD
Hmm, I don't think that this is a power problem. I've tried with a power supply and with a 9V battery. (The other sad-1 works with both)
Any other ideas? Thanks
Paul Marossy
Hmm... OK. Are there any electrolytic caps that look like they might be leaking? It sounds to me like your flip-flop circuit isn't flip-flopping...
HeaD
externally, elec. caps seems ok... anyways I will replace them...
HeaD
Hey Paul,
I've tried to replace the 0.47 electrolytic caps around the fet (you're talking about them?), but nothing... Can the problem depend on the delay chip or something?
Paul Marossy
Might be a bad delay chip - possibly. I would suggest feeding the circuit with an audio oscillator and using an audio probe to see where the signal stops. If it stops right the flip-flop, then maybe one of those devices is bad. If it makes it past there, then the problem is elsewhere.
HeaD
I've replaced the MN3205 with the one of the other SAD-1, and it works.... but now the "repeat" control seems to work strangely.
If I turn the "repeat" control all the way up, repeats are not infinites.... what can it be? Thanks again..
Paul Marossy
I'm not sure. I'm out of ideas for the moment.  :icon_confused:
While you're at it, you might want to socket whatever chips you pull out.
HeaD
Yeah, I'll do it :)
Could the amount of repeats depends on the two trimpots? Or maybe the MN3102? Thanks Paul :D
Paul Marossy
Well, the trimpots may have something to do with it. The 100K trimpot with the wiper connected thru a 100K resistor to Pin 7 of the MN3205 sets the bias. The other 100K trimpot connected to Pins 3 & 4 of the MN3205 appears to be some kind of balance pot. That's probably where I would start since that is associated with the Repeats control thru that UPC1571C chip.
