Adding a line out. . .
Started by Also Wik, September 17, 2006, 10:06:19 PM
Also Wik
I don't know if this really counts as stompbox DIY, but it does pertain to Guitar amps. . .
I want to add a line out to this little mini amp i bought (one of the Fender ones), so I can run it to a small cab i have with an 8" speaker in it. How would I go about doing this? If i wanted to turn it into nothing but a head could I just run the + and - speaker connections to a jack of some sort? If so, what kind?
Sorry, I couldnt find anything by searching.
Gilles C
I have the Mini Hot Rod Deluxe, and it uses the same IC than the Marshall MS-2 if I remember well. But the input circuit is different (of course...).
http://homepage.ntlworld.com/s.castledine/greenfuz/ms2.html
But there are a couple mistakes on that schematic. The 510 ohms is used only for the Headphones.
You can use a bigger speaker instead of the original one.
You can do this http://www.netads.com/~meo/Guitar/Amps/Kalamazoo/Mods/ezlo.html or this http://www.diyguitarist.com/GuitarAmps/LineOutBox.htm fo the line-out
Gilles
Also Wik
