Mosfet Booster with BS250
Started by ubersam, September 20, 2006, 02:56:32 AM
ubersam
I wanted to try an AMZ Mosfet Booster build but all I have at the moment are two BS250s. Can these be used insted of the BS170 if I flipped the power and the elect. caps? Or should I just try one section of the Obsidian?
pyrop
Hi ubersam, I would say either one would work fine.
You would have to flip the zener diode as well with the AMZ mosfet booster.
pyrop ;D
WGTP
Stomping Out Sparks & Flames
stm
#3
Sorry, posted in the wrong thread  :icon_redface:
ubersam
Very cool. Thanks guys. Just some questions about the zener diode, I seem to remember reading that if the Mosfet used has an internal diode protection, the external zener diode could be omitted. Is this correct? The datasheet for the BS250 shows a diode from the drain to the source, would this be the protection diode? Lastly, in the absence of a zener diode, could a regular silicon like a 4n400x take its place?
Thanks again.
WGTP
I think all the typically used Mosfets 2N7000/BS170/BS250's have the internal diode.  Some designs use an common LED for the diode to protect against static discharge frying the Mosfet.   :icon_cool:
