need a hi-gain transistor fuzz circuit to build
Started by guitarleeman, September 25, 2006, 01:33:57 PM
guitarleeman
Im looking for a super hi gain transistor fuzz circuit. I saw the plutonium fuzz but I havent built it yet. Is this a good hi gain circuit or is there one that hasnt been posted yet. Not with FET's but regular transistors.
3/4 North
There's two I've built so far that had a crazy amount of gain.
The Vulcan and a Blue Clipper with the discrete op amp.
fixr1984
RDV
Gus
I have a question why is the feedback R at the node of the 220 ohm and gain pot?
  I would think it would be at the emitter
Check Doug H's  hot Si
RDV
Quote from: Gus on September 25, 2006, 07:52:24 PM
You might ask Gary Hurst. He might know. I just copied the TB Mk. II and did what it took to make Si trannys work in it. It does work.
And Doug's Hot Si is an excellent choice.
Regards
RDV
tcobretti
#6
As 3/4N recommended before, I'd probly try this guy:
http://www.diystompboxes.com/analogalchemy/pedals/vulcan.html
However, I supect that it is more of a distortion than a fuzz.
If you want a crazy fuzz I'd probly build an octave fuzz.  They are all pretty crazy, but the Mayer Octavia and the Scrambler stand out to my ears.
Also, I ran a spice simulation of the Sam Ash and it was pretty freaking nasty.
brett
2nd for the Fuzzrite.  It goes where fuzz wasn't meant to go.  I suggest using low hFE transistors in it.
Brett Robinson
