Dist+ with diode switch vero layout: correct?
Started by otis_soulman, September 26, 2006, 04:35:56 AM
otis_soulman
Hi!
The italian diyer is back...  8)
I decided to build my very second pedal, following the Distortion+ I created a couple of weeks ago.
It's another Distortion+, vero layout again, with a clipping diode switch. Here it is:
http://stone8.altervista.org/documenti/render_distplus.gif
The pure Dist+ layout is the A. Carrel's one, untouched (apart from the extra-cut needed) and working. But I wonder if the wiring layout is correct: i mean the 3PDT, the DPDT (diode switch), and the ground wiring. It's my first attempt in writing down a layout by myself, "decoding" wthat I read from this forum and other stuff on the web, so I'm not so sure...  ???
A very big THANKS from Italy to the patience guy who will answer!  :icon_biggrin:
Bye,
   Otis
bancika
just one remark, instead of adding 4 strips at the beginning for diodes you could:
a) put them in the lower right part of the board
b) mount them on the switch
Other than that it should be fine
Cheers
Dark Fader
On my modded Dist+ I just mounted them on the switches (all five of them) as they are only weenie little things.
Cheers,
Jim
