A/DA Flanger does TZF?
Started by Dave_B, September 29, 2006, 05:34:12 PM
Nitefly182
Quote from: scottso on October 28, 2007, 05:44:56 PM
Changing R13 from a 10k to 4.7k did the trick.  The pedal sounds even better now that I could adjust TR1!  Thanks for the help!
Now my question is.. what do we do when you can't find the SAD1024 anymore? :)
Thats why Im trying to get a second board and another SAD1024 just to be sure.
Does anyone know what the 2 extra 27k resistors in the BOM are for?
puretube
http://www.diystompboxes.com/smfforum/index.php?topic=49929.msg385202#msg385202
or:
http://www.smallbearelec.com/Detail.bok?no=245
oldschoolanalog
Quote from: Joe Kramer on October 28, 2007, 02:28:31 PM
Hey, there's plenty of love to go around, especially for you Stephen, one of the original ganstsas of the DIY A/DA flanger!   :icon_wink:
You got that right. If not for Mr. Giles' willingness to share his expertise and experience with these flanger ideas, a hack job artist like myself would be still be shaking his head with a dazed and confused look (I still do, but that's another story altogether :icon_lol:)
StephenGiles: Godfather of things that go wooosh and swoosh ;D. Thanks again Stephen!
Glad you got that issue solved. Great pedal, eh?
No more SAD1024s will happen someday. Guess somebody will have to do another re-design, like when the MN3010 went (pretty much) extinct. Any volunteers?  :icon_lol:
Rock On!
osa
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
scottso
Yeah this pedal is awesome.  I feel fortunate that I had just stumbled upon the thread.  My next project wasn't even going to be a flanger. :)
What cases do you guys use for these?  I'm hesitant to lay out the bucks on a 1790 if its not going fit...  I'd prefer something with a little more room (I have fat fingers! :D)
Nitefly182
Quote from: scottso on October 28, 2007, 07:43:32 PM
I was planning on a 1790 and have one drilled if someone wants to give it a shot but one of the caps hangs over the edge of the PCB on mineso it didn't fit once I populated the board. Im thinking about using a hammond sloped enclosure right now.
Nitefly182
Just finished mine and it rules. I need some help with the functions of the individual trims though. Im very close but the sweep seems a little off axis. I also have a slight distortion problem  but its very minor. I'm pretty sure both of those are trim issues. Can anyone tell me what the functions of the individual trims are?
puretube
#726
http://www.diystompboxes.com/smfforum/index.php?topic=61368.0
looks like this:
http://img61.imageshack.us/img61/3381/img12200mo1.jpg
Nitefly182
A couple weird issues after some tweaking.
1. There seems to be a bit of background distortion when playing clean and I dont know where its coming from. Anyone else notice background distortion in their build.
2. The completed pedal runs fine on 9 volts... dont know what to make of that at all. Im not sure that the 18v supply I was using was actually putting out 18v though so I might need to go somewhere and get an 18v supply tomorrow. It doesn't sound excessively thin or lose headroom although the background distortion may be because I haven't used it at 18v yet. Still, I could easily use this pedal with a 9v supply which is weirding me out.
oldschoolanalog
Distortion as in the signal being distorted; or; distortion as in background noise? If it's the signal, I'd re-check the bias trimpot. If it's background noise, the gate should resolve it without issue. First get it the proper supply V and take it from there.
All the Best
osa
StephenGiles
The SAD1024 will run perfectly well on 9v if properly biased - run probably isn't the right word, but you won't have as much headroom.
Nitefly182
I recalibrated it after making an 18V y cable for my PPII and it sounds much better and the distortion is gone. Here is the retweaked and finished pedal:
oldschoolanalog
Nice job! I really like the use of the term "activate"!  :icon_cool:
osa
Nitefly182
Thanks. For such a complicated pedal this wasn't all that hard really. I had the one issue with power but otherwise it worked right off that bat.
StephenGiles
No, it's not crappy at all, it sounds brilliant. I next have the house to myself next Monday so ........amp up to 11 and full ADA sweep!!! :icon_biggrin:
oldschoolanalog
Quote from: StephenGiles on November 01, 2007, 02:33:40 PM
Don't forget to use an "octave doubling" distortion in front of it!  :icon_twisted:
osa
Nitefly182
Ive used in my rectifier's loop and it sounded great. A modded screamer clone also produced great results but I think a muff may be the trick for massive jet flybys.
stumper1
I'm finally working on my Rev01 board.  For C6 should I use a 2.2u polarized electro or 2 1u tants? If I use the electro, which side is which?  With the tants, I believe I should wire (-) to (-).  Is that correct?
Deric®
A 2.2u electro will be fine the positive side goes towards the diodes (D2 and D4).
stumper1
Deric®
