millenium bypass LED value
Started by blanik, October 02, 2006, 02:03:36 AM
blanik
the battery in my rebote 2.5 just died today, i like this effect because when the battery dies it just starts to oscilate like crazy so you can't miss it!!  so the battery lasted a long time but my LEDs are high brightness ones with only a 2k2 resistor so i guess they count for a lot of draw...
is it possible to change the value of the 2k2 resistor in the Millenium bypass (tonepad schem) without screwing up the millenim bypass ?
R.
If tonepad did their schematic correctly, yes, you can use about any value you like bigger than that.
