cross reference parts for elec-mistress non-delux
Started by bent, October 04, 2006, 03:38:26 AM
bent
hi, i'm building the non-deluxe electric-mistress find at http://www.freeinfosociety.com/electronics/schemview.php?id=383
just can't find the 2n5037 , i think it's a 12 volt regulator, so i thinking of using a 78L12
but for the 2N3563...i really don't know...it's look like a zener diode but can't figure witch one to use....
any clue?
thank's
bent
Long live the music.....
cbriere
You right, the easiest way is to replace
the 741,
100K res,
2 zener
pass transistor
by 78L12, 12V/0.1A regulator
bent
thank's cbriere,
can't figure out how to do it, do you think you can make me a little schema , so i understand better the way to do it.....?
thank's again
bent
StephenGiles
bent
are you certain stephen?
2n5037 is a NPN
and
2n4354 is a PNP
bent
bent
#5
my problem by replacing all the 741 , resistor, zener diode   with a NTE950 (12 volt regulator) or lm78L12
is the little /%?/&!"("  :icon_evil: &*/?*  :icon_evil: "(())) !!!!!  connection between the 741(pin 3 +) and the trimmer 100k in the bottom....
NTE950 datasheet: http://www.nteinc.com/specs/900to999/pdf/nte950.pdf
lm78L12 datasheet: http://www.futurlec.com/Linear/78L12.shtml
my guess is :
Vin is 18 to 24 volts  (pin1)
Vout is 12 volts  (pin3)
ground (pin2) go to trim 100k/ resis 18k / resis 30k
is it how to convert the 741 / 2n3563 / 100 k    with a NTE950-12 volt reg
bent
cbriere
cbriere
seems like impossible to put a link,,
PM me at cbriere36@hotmail.com for a schematics
puretube
StephenGiles
Quote from: bent on October 05, 2006, 01:44:36 AM
2n5037 is a NPN
and
2n4354 is a PNP
bent
2n5037 is wrong, it must have been 2n5087 - I'll check on the various versions I have.
StephenGiles
puretube
bent
