Parts ID
Started by Barcode80, October 09, 2006, 01:38:04 AM
Barcode80
I pulled a few jacks from the zoom i just salvaged and among those parts were 4 jacks. they appear to be stereo, but i can't tell because they are enlosed PCB mount jacks and i can't see the post pattern. below are pics. can anyone who has used these before give me a lug layout as to which pin is which? They are remarkably sturdy and i want to use them in a build soon.
there were also about 6 pots in the unit that are VERY tiny but seem to be taper pots, not trim pots. they are marked with "103B" on the back. does this mean 100k linear? what do you guys think?
zyxwyvu
Looks like stereo to me too. An easy way to tell what each pin on the jack is for is to plug in a cable and use your multimeter to find which pins connect to where on the cable (tip, ring, sleeve).
103B sounds to me like 10K linear (10 * (10^3) = 10,000).
