trimmer question
Started by Crawf, October 11, 2006, 05:08:49 PM
Crawf
Hi, Is it possible to have an internal trimmer wired to the outside of the pedal box using a pot of the same value to save opening the box to tweak the sound? cheers Crawf.
Seljer
Crawf
Thanks,Would the pot Log or Linear or does it matter? Crawf.
bancika
I would go with linear, but it does not matter much because it is not a thing you will change all the time  :icon_wink:
markm
Linear would behave more like the trim that's being replaced.
mojotron
Check out the sun-dial on the Sun Face by Analog Man
The face moves with a pot that's under it. When I saw that I thought it was one of the coolest ways that this sort of thing could be done
Crawf
Thanks folks, the reason i asked was that a buddy asked if i could make the Joe Gagan Nitroburner but to have the internal trim pot externally mounted and as i wasn`t sure i thought i`d ask the question, cheers Crawf.
