Ques. about types of transistor based circuits
Started by tcobretti, October 14, 2006, 12:45:24 AM
tcobretti
At some point I read a post (I believe it was R.G.) that said that a Fuzz Face was one of the six (?) types of basic transistor based amplifying circuits, and later I read that an Axis Fuzz was another one.  I searched, but couldn't remember enough to search effectively.  Can anyone give me some clues so I can study the different types of circuits?
Just trying to learn a little.  Thanks.
Seljer
I believe they'd be  common collector (this is your most common amplifier that you often find), common emitter (this basically a buffer most of the time) and common base (but I don't think i've ever seen this setup used in a stompbox); as well as common gate, common source and common drain with FETs
http://www.ibiblio.org/obp/electricCircuits/Semi/SEMI_4.html#xtocid55704
http://en.wikipedia.org/wiki/Category:Electronic_amplifiers
Thomas P.
yes, common base and common gate aren't what would be called an amplifier around here. But they are used at higher frequencies (~MHz) because of the higher bandwidth. They also got a very low input impedance (compared to common emitter).
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
Paul Perry (Frostwave)
Here be wisdom... http://en.wikibooks.org/wiki/Electronics/Amplifiers
Note that only the common emitter & emitter follower are at all simple to bias.
Note also that when you go from one to two transistors, there are naturally a lot more combinations, cute ways to bias... and then ther eis the whole NPN/PNP thing as well.
All of which is quite different from the Class A, B, etc etc amplifier modes!
tcobretti
Thanks for the help, that gives me some good stuff to study.
Sir H C
Quote from: tomboy on October 14, 2006, 03:43:48 AM
Well the differential pair uses the common base/common gate configuration.  Anything with a cascode is also common base.
The coolest use of common grid is Peavey and some Musicman amplifiers that used transistors to drive the cathodes of the power tubes.
