Ross Compressor/Sustain Clone 3DPT Addon
Started by nephsuperman, October 14, 2006, 11:14:34 PM
nephsuperman
Hello,
I am doing my second pedal ever and I still feel like a newbie, and rightly so.  Well I am building the Ross compressor from General Guitar Gadgets located at:
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=148&Itemid=175
The one that they have up there is using a Millenium Bypass and I purchased a 3DPT switch.  I am trying to figure out my wiring so I can get this thing going.  I am not sure where the wires should go and where they are coming from.  Plus I also want to add a light, as seen in the picture.  Any help would be MUCH appreciated.
Thanx
4 successful builds, 2 on the way.  Still trying to learn as much as I can.
GGG tube screamer *2, GGG ross compressor, and the GGG Crybaby replacement circuit.
dmk
resistance is futile...
...if <1Ω
bancika
you don't need millenium if you have 3pdt switch, it is sufficient for true bypass and LED indicator
nephsuperman
Oh that is a sweet link, thats for the info.  I couldnt find that one on GGG, but I guess I wasn't looking hard enough.
Thanx.
