Pedal draining batteries
Started by Cardboard Tube Samurai, October 17, 2006, 08:31:16 AM
I made a pedal for a friend and he refuses to use power supplies so I put a 9v battery in it for him (it's the first pedal I have made that doesn't use an external power supply). When it's not in use (no input/output jacks), it drains the battery. What would cause something like this? Could it be fixed by something as simple as putting an on/off switch on say the negative wire to the battery?
dano12
Sounds like incorrect wiring on the input jack (which is used as a switch for the battery). This page should help explain how to wire it all up:
http://beavisaudio.com/techpages/StompboxWiring/index.htm
MikeH
Does it have a DC jack too, or is it just the battery?
captntasty
Is anything else (aside from battery neg lead and lead to ground) grounded to the input jack?  If so, there may be a continuous path to ground, thus nullifying the power switch.  If it's not that, something else is doing the same thing - the power switch does not break the path to ground.
It is no measure of health to be well adjusted to a profoundly sick society. - Jiddu Krishnamurti
MartyMart
As stated, check your stereo jack socket, I'll bet that it or the board
is shorting to ground .... battery probably gets V- hot too !
MM
MetalGod
one easy way to check is to use a DMM and see if you measure any voltage in your circuit.
Stop looking!!! I found the problem... I think I should explain things a bit further before everyone jumps to the conclusion that I am a little crazy! I originally made the pedal for the guy... it worked, but wasn't the sound he was after. I took it home and modded it (changed a couple of caps etc.)... took it back to him and it didn't work... turns out the battery was flat... changed the battery and all was well, he loved the sound. I took it home again though so that I could add an on/off indicating LED which I didn't include originally but he wanted. When I took it back to him again, it didn't work. It was at this point, I assumed it was chewing batteries and made this thread. So I pulled it apart to check the grounding as you guys suggested. When I looked inside, I found that I had broken a wire off the output jack when I put the LED in. I am guessing that when I modded it for him with the new caps, I accidentally put a flat battery back in instead of the good one I had taken out.
What can I say!? I'm only human!
