resistor from base to collector question...
Started by MetalGod, October 17, 2006, 01:10:29 PM
MetalGod
ok, not being very hot on the tech side of this stuff I was wondering... what effect does putting a resistor from collector to base have on a simple single transistor stage?
8)
  It pulls the base bias up toward the Collector.
Gilles C
#2
Here is a llttle info about the different ways of biasing a transistor
http://web.telia.com/~u85920178/begin/bias-00.htm
Check the second method compared to the first one
Still more info
http://www.tpub.com/neets/book7/25c.htm
http://www.tpub.com/neets/book7/25d.htm
Gilles
MetalGod
thanks for the replies - thats exactly what I was looking for Gilles C.
think I'll wire up those basic single transistor circuits and play with them to see what SOUND difference there is - afterall, thats all that matters right? (rhetorical question)
8)
Gilles C
You got it right.
The best way to learn is to start with the basic circuits, play with them, have fun. Then, you"ll realise that everything you see is a lot of circuits that you understand.
The next step will be to understand how little circuits inter-react together when connected together.
Good luck and have fun.
Gilles
