GGG Modable wah inductor Q
Started by audioguy, October 19, 2006, 08:01:50 PM
audioguy
Some time ago I built the modable wah from GGG... I love it! HOWEVER< I cant hear a difference in the inductors. Im using a yellow and a red fasel, When I run them together it sounds amazing, but when I switch from one to the other- no noticable change in tone. Are they that close in tone, or do I maybe not have it wired up correctly?
Since the diagram on GGG shows the larger 'stack of dimes' type of 4 connection inductors, I planted these in the only set of holes they'll fit in, with both cups facing in to the board.
Does this sound about right?
Audioguy.
jonathan perez
show a picture?
i can safely say the two sound different, but...its not night and day, to me.
do you have any other inductors to change between?
audioguy
OH yeah... the pots- are those Lin or Log? Im not sure if Im getting the correct sweep on it... I mounted them like a Dimebag wah, and used lins. I found sweet spots, so I dont tweak it much... just thought I would ask in case Im missing something.
audioguy
I might be able to do a pic...
Sadly no other inductors available.
jonathan perez
what do you mean no other inductors are available?
get that pic up so i can see what youre getting at.
audioguy
I just meant I have none on hand to experiment with... anyway... heres a quick diagram. I think you sould be able to get the picture of what Im doing.
Paul Marossy
I can hear hardly any difference between the red and yellow Fasels. I have used both of them in several different circuits.
audioguy
Thanks for the info Paul. Its never really bothered me in the past because when I use them together it sounds amazing... so I almost never switch to Y or R. I just thought I would check to see if I was missing something. I might have to experiment with some of the other inductors floating around on the web.
