LPB-1 Help!
Started by milt, October 20, 2006, 09:22:48 PM
milt
Hey There,
I just built the LPB-1 (Dragonfly vero layout), It sounds great and has a lot of boost. The volume pot works backwards though!! I've been over it with a fine tooth comb and still cannot work out my mistake. I tried installing another pot of the same value and had the same symptoms.
At this point the only thing i can think of is that the transistor may be installed incorrectly (2n5089). Would this mistake provide the symptoms I describe???
Thanks,
Milt.
Rattlehead
I have the same exact probelm.
i built a LPB1 and the pot work backwards.
anyone know what's the problem?
milt
Thanks!!!
Now I don't feel like such a bonehead!
Did you use the dragonfly layout?
boogietube
I believe that the pot is wired backwards. Someone correct me if I'm wrong.
Reverse the outside wires on the pot and it should work.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
Rattlehead
Quote from: boogietube on October 20, 2006, 09:34:50 PM
I already did,doesn't work
milt
I also tried reversing the wires on the pot.
Milt.
skiraly017
Try reversing lugs 3 and 2 instead of 3 and 1.
milt
I also tried reversing lugs 2 and 3. I'm kinda stumped at this point.
  Lug 3 gets circuit output [this is the 'input of the volume pot]
  Lug 1 goes to ground.
  Lug two is the volume pot output and goes to switch/output jack.
  The two outside lugs should at least have circuit output and ground, if the VC knob works backwards, reverse the outside lug connections.
  I go by bias voltage, but if the thing is boosting alot, the board and transistor are probably wired correctly.
milt
Thanks!!!
It worked.
Dragonflys vero layout has lug 3 going to ground and lug 1 as the circuit output.
Thanks a bunch.
burnt fingers
I still wire my pots backwards half the time.  If it's a linear pot I'll just leave it. It messes people up when they play on your gear.  I also use audio pots wired backwards for gain on My D+ and a few othe drive pedals.  It is a matter of convinience as I don't need to order anythng from smallbear right now so I don't want to pay shipping on just a couple revers log pots.
Scott :icon_biggrin:
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
  I just turn the dial "Up" toward the input lug.
  Say lugs on bottom shaft pointing at you, turn the knob to 5:00 Fully CWise, the lug the knob would point at..that is the 'input' of the pot and is fed the circuit output.
Dragonfly
glad youve got it working....
i added the words "top view of pot" to the layout, so people dont get confused in the future.....
AC
milt
Quote from: Dragonfly on October 21, 2006, 08:39:55 AM
AC
Awesome. Thanks for your layouts Dragonfly, I'm having a ton of fun with them!
Milt.
